On 2004-06-18 08:14, Captain_Rat wrote:
Rags,
Since I'm not sure about track protocols, I don’t' know if you can just disconnect the fuses for the lights. If so, the following are the fuses that effect them (the numbers below are indicated on the fuse box):
- Fuse #1: Dip and main beam headlights.
- Fuse #9: Lighting.
- Fuse #10: Sidelights.
I didn't see in the manual where it explains how to disconnect the light, but if you send me your email address in a PM, I will reply with screenshots of the light schematics from the manual.
Also, the manual was mailed to you on Tuesday. Should be there soon.
Capt. Rat
Capt.,
Thank you! I wasn't sure removing the fuses would be a good idea (was worried that the Computer will complain of a malfunction).
You got PM
Thanks again for the Manual!
