I had the same thing on mine after a brake bleed, I used a flat screw driver between the brake pads and disk to push the pads back and re-pumped them back, Ticking was gone.
I believe it was a stuck caliper... has never ticked since.
Simple enough to try and eliminate at least one possibility.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
