Trident-Exhausts.comMotorcycle.comSportbikeTrackGearShopTriumph.comMotorcycle.com Classifieds!BikeBanditAdvanstarMotorcycleShowsRacerPartsWholesale
SportbikeTrackGear
Old 07-05-2006   #1 (permalink)
I know I have seen this posted but now I can't find it with the search function (imagine that).
Can anybody confirm that the Australian and/or South African spec bikes do not have the Secondary Air Injection (SAI)? I am going to have my new S3 delivered with Trident 1/2 pipe system and the map changed. If there really is such a thing as an Aussie TORS tune without SAI then that is what I want to get. Then I can unplug and eliminate the SAI hardware without having to add a resistor or worry about getting a MIL light.
dr_gallup is offline   Reply With Quote
Old 07-05-2006   #2 (permalink)
Hey doc,
As far as I know there are only two Tors tunes, one for the California Model and one for the rest of the world.
Check this thread:
Air Injection Removal
Avi8tor posts up some tune numbers.
Mine is currently running 20103. (Staintune Pipes)
[ This message was edited by: Legman on 2006-07-05 21:13 ]
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 07-05-2006   #3 (permalink)
It's anecdotal but I must say that after living in Australia for a couple years I learned that very little was ever custom for that market. A country with the population of CA doesn't get much of that financial pull.
Legman–I love your quote!!!
"The person who says it cannot be done should not interrupt the person doing it." - Ancient Chinese Proverb
'we are all born naked and screaming and if you're lucky that sort of thing won't stop there.' -unknown
abelard is offline   Reply With Quote
Old 07-06-2006   #4 (permalink)
Actually 4 tunes for the S3. Take yer pick.
All VIN's
20100 1050cc Speed Triple with standard exhaust with catalyst and secondary air injection
20101 1050cc Speed Triple with standard exhaust
20102 1050cc Speed Triple with aftermarket exhaust with catalyst and secondary air injection
20103 1050cc Speed Triple with aftermarket exhaust
Avi8or is offline   Reply With Quote
Old 07-06-2006   #5 (permalink)
All VIN's
Are those Triumph tune numbers or Tuneboy numbers? I'll forward the number to ny sales guy if it is a tune number the dealer will recognize. I want the 20103!
Old 07-07-2006   #6 (permalink)
I got those off the Tuneboy site. However when I went to my Triumph dealer to load a map, a choice of four maps similar to the tuneboy maps came up on his handheld triumph computer gadget.
After a few minutes head scratching as to which was the most suitable 20102 or 20103, we decided to go with the CAT/SAI version the 20102.
Was OK for the TORS, but since I've fitted a ZARD and have a tuneboy I went with a modded tune supplied by Wayne (Tuneboy) based on the 20103 map.
Tons of backfires with this latter map so I blocked off the SAI pipe and only a few burbles now. THis map is pretty good and am very happy with it.
Waiting for my mate to install a wide band lambda probe and do a few data logging runs, maybe we could refine the map a bit for my particular bike and enviroment.
Old 07-07-2006   #7 (permalink)
Thanks Avi8or. I told the dealer to install the Triumph tune for TORS without SAI. Hopefully that will work with the SAI removed. I may have backfires until I get the SAI blocked off as I have read the solenoid is normally open. I only have to drive it 5 miles from the loading dock to the house tomorrow.
TORS tune from dealer or Tuneboy tune? Max_NYC Speed Triple Forum 25 07-06-2007 11:22 PM
TORs tune - did i get the right one? jpeake Speed Triple Forum 6 05-08-2007 04:03 PM
TORS Tune Map Problems DeanRider Speed Triple Forum 13 01-13-2007 03:07 PM
Zard with a TORS tune Trumpy1050 Speed Triple Forum 17 01-12-2007 06:05 AM
TORS/Off Road Tune which Octane 89 or 93? mdallas Speed Triple Forum 8 09-29-2005 12:09 AM
