SportbikeTrackGearBikeBanditSpringfield ArmoryRacerPartsWholesaleAdvanstarMotorcycleShowsShopTriumph.comTrident-Exhausts.comMotorcycle.com Classifieds!
SportbikeTrackGear
Old 07-04-2006   #1 (permalink)
Wow!!! I had an absolute blast this monday...First track day at Mid-Ohio race track and the triple loves the track especially after the suspension was dialed in...So here is the set up that section8superbike came up with for me 6' 1" 198 lbs in full riding gear.
FORKS Preload( the blue head ) out so you can count 6 lines.
Rebound 1 turn from full in (Left screw)
Compression 3/4 turn from full in (Right Screw)
Rider sag 35mm
Rear Shock Preload (The spring) Showing 5 1/2 threads from the top. This they cranked down two full turns.
Rebound 3/4 turn from full in (Lower screw)
compression 1 1/4 from full in (upper screw)
I hope this helps... it made a huge difference I had it done after the first two sessions and it made the other 4 alot more enjoyable...I will post some pics soon...
2005 Speed Triple, BMC air filter, Blue Flame EVO's, Power Commander, Matris M4R,Skyking sliders,Sargent seat,WoodCraft clip ons,
http://i72.photobucket.com/albums/i1...IMG_1267-1.jpg
hool-a-gan is offline   Reply With Quote
Old 07-04-2006   #2 (permalink)
tsc17's Avatar
Glad to hear that you did well with proper setup. I love Mid-Ohio, have ridden it many times, and look forward to getting some tracktime in there this year with the new surface.
How much did they charge you for your setup?
2006 Speed Triple. Black. Too many mods to list!
tsc17 is offline   Reply With Quote
Old 07-04-2006   #3 (permalink)
Wow, makes me feel like a fatass. I've got my fork preload showing only 2 lines, but I'm about 260 pounds with gear on. This is what I needed to get about 31mm sag on the front. Rear preload is about halfway down on the threaded portion. I'm using the comp and rebound setting from the manual for their recommended "firm" setup. The fork, feels great, very precise, not too harsh (although still not locked in like my Bandit 1200 forks after RT springs and valves). The rear needs more comp damping, but still worlds better than the stock setting.
bikeman is offline   Reply With Quote
Old 07-04-2006   #4 (permalink)
The new pavement was awesome...They charged $50 for the set up...one time charge and you could bring the bike back to them all throughout the day to make changes...They were really great and they have plans to be back to mid-ohio...
When are you thinking of going to mid-ohio tsc17? I'm already trying to make arrangements for aug 1st...
Old 07-05-2006   #5 (permalink)
tsc17's Avatar
I'm not sure exactly which event(s) I will attend. I need to get in touch with Monte at STT...
I'm sure the surface is great, but now all of my reference points will be gone! All of those cement patches were great for reference. Oh well, I guess it's an excuse to learn the track all over again.
Where about in Ohio do you live?
Old 07-05-2006   #6 (permalink)
I'm about 25 minutes south of cleveland and 100 miles north of columbus...your lucky you have alot of great roads down there....
Old 07-08-2006   #7 (permalink)
I'm gonna give your settings a go too.
I'll let you know how I get on.
MH
Rider sag 35mm
If it looks like an Aligator,
Walks like an Aligator
and
Bites like an Aligator.
It could be a Crocodile......
MonkeyHanger is offline   Reply With Quote
Old 07-10-2006   #8 (permalink)
Man that is a seriously firm ride. Great for the track but just a bit hard for the UK roads.
MH
Rider sag 35mm
and
Old 07-11-2006   #9 (permalink)
There goes another potential setup up in smoke. If that's hard for UK roads then major bone shaker and loose tooth fillings over here.
If you Brits think you have bad roads then come over here for a real eyeopener. I know, I've driven on both.
[ This message was edited by: Avi8or on 2006-07-11 06:18 ]
Avi8or is offline   Reply With Quote
Old 07-20-2006   #10 (permalink)
Doesn't six lines of preload effectively soften the spring rate of the front end or are these single-rate springs?
JW
2k7 Sprint ST w/ABS (crashed)
RoadBuilder is offline   Reply With Quote
Mid-Ohio is right around the corner! boozefighter Biker Hang-Out 26 07-21-2008 09:22 AM
07 Speed Triple suspension set-up help ??????? leeshelford Speed Triple Forum 1 07-21-2007 04:41 PM
Mid-Ohio Mancha Club Cafe 0 08-14-2006 12:04 PM
Mid-Ohio tour pbpeel Ride / Trip Reports 5 07-18-2006 11:14 PM
05 speed trip suspension settings chrisf Speed Triple Forum 2 06-16-2006 11:05 AM
