Has anyone checked oil temperatures in his 1050? When I change the oil, I'm always surprised how cool is the oil. I'm kind of thinking the engineers switched to the smaller oil cooler because the oil stays too cool with the larger one. Thoughts?
I'm thinking of checking the oil temperature next time I change it. What is the ideal oil temperature under normal operating conditions. I'm thinking maybe 220 degrees---hot enough to boil off water/condensation, but not so hot as to cause the oil to break down prematurely. Thoughts?
By the way, my '06 has the larger oil cooler.
