Trident-Exhausts.comSportbikeTrackGearRacerPartsWholesaleMotorcycle.com Classifieds!ShopTriumph.comAdvanstarMotorcycleShowsSpringfield ArmoryMotorcycle.com
Old 07-03-2006   #1 (permalink)
I just bought a set of Kellermann Micro 1000 LED signals and a Trick Flasher Relay:
http://www.customdynamics.com/trick_flasher.htm
It's the third one down...I cut the connectors off and installed crimp on spade terminals (male). I unplugged the stock flasher and plugged in the new electronic flasher. It works like a charm! It has 5 different flash patterns selectable from the turn signal switch. LED flash rate problem solved....
http://www.grahamcrosby.com
To do is to be. -Descartes
To be is to do. -Voltaire
Do be do be do. -Frank Sinatra
GrahamC is offline   Reply With Quote
Old 07-04-2006   #2 (permalink)
Hey bud, You're gonna have to show me that trick if I buy an S3.
Thunderpunk is offline   Reply With Quote
Old 07-04-2006   #3 (permalink)
You got it! It takes about 10 minutes. I'll show you Thursday...Go on and pull the trigger on that S3!
Old 07-04-2006   #4 (permalink)
Favorite Bike: '01 Speed Triple
Thank's for that, Graham! I have the Kellermanns, and they are the best. I am using 4 resistors, but that flasher will do the trick nicely! And clean up under the seat.
Speed3 is offline   Reply With Quote
Old 07-04-2006   #5 (permalink)
Graham, you got a link for the kellermanns? Thanks
1050Pome is offline   Reply With Quote
Old 07-04-2006   #6 (permalink)
Here are 3...
http://www.whaccessories.com/TriumphAccessories.htm
http://www.newspeed3.com/html/keller...n_signals.html
http://www.spieglerusa.com/cfm/kellermann.cfm
They are a little expensive, but EXCELLENT quality and very, very bright...
LED Flasher Option Ferris Speed Triple Forum 0 09-19-2007 04:30 PM
LED flasher unit trouble ? Help pls wispspeed Speed Triple Forum 9 06-19-2007 10:11 PM
LED Indicators / Flasher Unit Blackjack Twins Technical Talk 1 03-12-2007 10:16 AM
gsxr footrest and LED license plate LED brake light installed MotoRaider Speed Triple Forum 19 01-23-2007 10:13 PM
LED/Low wattage indicator flasher rate fix--sorta FelixLeiter Speed Triple Forum 3 04-27-2006 06:34 PM
