Old 07-02-2006   #1 (permalink)
I noticed on Tuneboys website, the tunes list have air injection and catalyst on some. How do you know if you have this or not? Is this a California thing?
Thanks for the help :???:
wkboardr is offline   Reply With Quote
Old 07-02-2006   #2 (permalink)
If you have a USA bike then you bet your bottom dollar you have the catalysts and Sec Air Injection. CA chaps also get an extra canister of some sorts.........
[ This message was edited by: Avi8or on 2006-07-02 14:21 ]
Avi8or is offline   Reply With Quote
Old 07-02-2006   #3 (permalink)
Look at the top of your motor. If you have a hose coming off each cylinder then you have a secondary air injection system. The solenoid for the system should be in the air box. The cali carbon canister is a forearm-sized cylinder which hangs on the backside of the motor under the fuel injection rail (under the fuel pump part of the tank).
The Non-SAI maps essentially tell the ECU the bike doesn't have those bits and it ignores the solenoids. I went the extra step and stripped my bike of those bits to shave a little weight and give more room for cable tidying. Makes it a bit easier to remove the airbox with all those hoses gone too.
Anyone try out custom Tuneboy tunes yet harlam Speed Triple Forum 0 05-02-2007 03:25 PM
Tuneboy Tunes timoteusmunk Speed Triple Forum 2 01-21-2006 08:00 PM
Tuneboy custom tunes for S4? johnshumpert Triumph SuperSports 7 11-22-2005 08:03 AM
tuneboy tunes Agkistrodon Speed Triple Forum 0 11-09-2005 12:40 PM
TuneBoy Tiger Tunes Hayduke Tiger Chat 2 03-31-2005 06:24 PM
