Old 07-02-2006   #1 (permalink)
i just filled my 05 spd triple with juice and got a pathetic 88 miles out of it before the fuel light came on. i do thrash about alot but is that a normal figure?
i always fill up when light comes on as i dont know how many miles i'd get on reserve. im off on a 2000 mile trip soon so i need to know what others are getting out of a full tank of gas on the new triple
cheers celt
officer you try and keep it on two wheels
Celt is offline   Reply With Quote
Old 07-02-2006   #2 (permalink)
I got exactly 111 miles to a full tank, I know this because my red light came on at 98 miles, so I assumed I had at least 20 miles on a red light, however much to my mates amusement I ran out, so much embaressment and carrying of petrol cans on the back of my mates bike ensued !!
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
Old 07-02-2006   #3 (permalink)
Celt, I have a 06 white s3 and so far it seems to be very sensitive to how I ride it. If i ride like a cretin :wink: it drinks the juice. However I have managed 110 before the red light and about another 30 miles after.
The average on the display normally seems between 45-50mpg.
no idea how accurate this is because I know computers lie.
And I know the motors in these things are on the rich side which does not help !
Cheers Slip.
slippery is offline   Reply With Quote
Old 07-02-2006   #4 (permalink)
Celt, it depends on how I am riding.....if I am giving it some stick the light comes on at 180Km (112miles) and general riding (cruising at 100 - 130kph (60 - 80mph) it comes on at 195km (122miles). If I fill at the time the light comes on it takes about 13 litres (2.9 imp gallons or 3.43 US gallons)
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 07-02-2006   #5 (permalink)
Thanks for the info. I was thinking of getting rid of my 03 for an 06 but couldn't live with the range.
The 03 has a 5.5 gallon tank and I can go 160 miles before the low fuel light and it still only takes 3.5 gallons so that should leave me enough to do over 200 miles easily.
Brodie is offline   Reply With Quote
Old 07-02-2006   #6 (permalink)
Limited Access
I ride pretty hard, get 130 miles before fule light, 3.5 gal. I tried riding easy on a tank just to see the difference, got 147 before fuel light. under a hundred miles seems very low.
Limey is offline   Reply With Quote
Old 07-02-2006   #7 (permalink)
I have a little over 3000 mi on my 06 and have been keeping track of gas mileage and i consistently get 35 miles to the U.S. gallon driving to and from work and get 42 miles to the U.S. gallon on the highway. Low fuel light comes on having used 3.5 or 3.6 U.S. gallons.
The older I get the more I learn how little I really know.
http://www.sloganizer.net/en/image,s...hite,black.png
speedcubed is offline   Reply With Quote
Old 07-02-2006   #8 (permalink)
I usually get the light at about 140 miles. It takes about 3.5 gals to fill up so I guess I still have about 1.25 gals left. That should be another 40 to 60 miles...I'm guessing I could get around 200 miles before I ran out...not bad.
http://www.grahamcrosby.com
To do is to be. -Descartes
To be is to do. -Voltaire
Do be do be do. -Frank Sinatra
GrahamC is offline   Reply With Quote
Old 07-02-2006   #9 (permalink)
i am averaging 130 miles before the fuel light comes on.
tekmoe is offline   Reply With Quote
Old 07-02-2006   #10 (permalink)
My light comes on at 100-108 miles under normal conditions, and if I'm racing it's more like 88-95 miles. Bike is very sensitive to how you ride it.
My best ever milage was 40, and I average about 32. (By measure and math, not dependent on the Trip computer)
These bikes also differ considerably between units. I rode with an identical bike over an identical distance where we split the time in the lead. Result: Me- 32 MPG, Him-40 MPG. I don't know why. (No, I'm not fatter.)
Slippery, your trip computer is set to Imperial gallons and miles. Hold down all three buttons until you see a single number. I bet it's 2. Change it to 3. It will still be optimistic, but much closer to fact.
crashmasterd is offline   Reply With Quote
tank range abruzzi Tiger Chat 11 06-20-2007 11:55 PM
Tank range tango Trophy 44 08-29-2006 02:55 AM
Tank range and possible petrol leak? pgatensuk Tiger Workshop 30 06-30-2006 03:51 PM
mileage/tank range thruxpunk Twins Talk 31 06-16-2006 01:12 PM
Touring Range of Tier Tank Jamo Tiger Chat 6 06-23-2005 05:30 PM
