If all is well again in ECUs mind, eg. no sign of error any more, the indicator light should go out after three heat cycles. That is warming the bike up to proper running temp & cooling down again x3.
Do you know what caused the light in the first place & have you corrected the cause?
[ This message was edited by: Martin_R on 2006-06-25 10:40 ]
