Motorcycle.com Classifieds!RacerPartsWholesaleSportbikeTrackGearSpringfield ArmoryBikeBanditShopTriumph.comAdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 06-22-2006   #1 (permalink)
Favorite Bike: 2002 Speed Triple
Tried the search feature with no luck.
It's time to replace the rear tire. I have a Michelin Pilot all ready and waiting. I want to remove the rear wheel so I can just take it to the shop and have them mount the tire. The service manager said to just remove the safety clip and loosen/remove the big nut. Is it really that simple? Is there anything else to do? What about the chain and sprocket and the brakes?
FYI, it's an 02 Triple.
blinker is offline   Reply With Quote
Old 06-22-2006   #2 (permalink)
Favorite Bike: 1050 Speed Triple
Raynewb's Avatar
Other Motorcycle: 04 Sprint ST
Extra Motorcycle: 05 tt 600
It really is as simple as that. Up on the single sided rear stand, free the clip which stops the nut rotating. Unlock the nut, wheel comes off leaving the chain and brake disc in place. Couldn't be simpler.
I do my own tyres in 30 minutes these days.
Ray
Stay safe and be happy
Raynewb is offline   Reply With Quote
Old 06-22-2006   #3 (permalink)
What tools do you use to mount and balance them?
[ This message was edited by: Curmudgeon on 2006-06-22 13:23 ]
Curmudgeon is offline   Reply With Quote
Old 06-22-2006   #4 (permalink)
nyburner's Avatar
That stuff is hub-mounted, not attached to the wheel, so you are good to go. You will obviously have to remove the can to pull the wheel off, unless you have an undertail exhaust. Just make sure you remember the order and sides the spacer and dish-washers go on when you re-install.
nyburner is offline   Reply With Quote
Old 06-23-2006   #5 (permalink)
I have a high-mount exhaust, so the whole removal process to less than 5 minutes. Talk about easy!
Old 06-23-2006   #6 (permalink)
Unless you have a Catepillar bulldozer tool kit you'll spend more time finding the socket than removing the wheel. It's huge - Sears doesn't have it. Got mine off a Mac tool truck.
Ricochet_Rabbit is offline   Reply With Quote
Old 06-23-2006   #7 (permalink)
What size is it?
http://www.grahamcrosby.com
To do is to be. -Descartes
To be is to do. -Voltaire
Do be do be do. -Frank Sinatra
GrahamC is offline   Reply With Quote
Old 06-23-2006   #8 (permalink)
On 2006-06-23 13:28, GrahamC wrote:
What size is it?
46 mm.
Old 06-23-2006   #9 (permalink)
nyburner's Avatar
No, they dont carry metric that big...but a standard 1-13/16 inch works...and that they do have.
[ This message was edited by: nyburner on 2006-06-23 14:19 ]
Old 06-23-2006   #10 (permalink)
This thread shows what I think is the best socket.
Removing Rear Wheel Without a Paddock Stand HoustonTriple Speed Triple Forum 7 05-17-2007 09:49 AM
Removing back wheel JayArr Speed Triple Forum 3 05-05-2007 08:32 PM
removing the rear wheel jnicosia Speed Triple Forum 5 08-15-2006 04:25 PM
Removing Rear Wheel msparks Sprint Forum 6 08-08-2005 06:49 PM
Removing & Replacing rear wheel on Y2K-TBS Modifications & Workshop Talk 29 07-29-2003 07:38 PM
