Motorcycle.com Classifieds!RacerPartsWholesaleSportbikeTrackGearSpringfield ArmoryBikeBanditShopTriumph.comAdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 06-22-2006   #1 (permalink)
So I was reading the post about shifting, and saw the link that showed how to do clutchless shift. I was trying out this morning on my way to work and liked it. My question is how does this affect the bike? Will it cause any extra wear and tear over using the clutch?
jackelmatador is offline   Reply With Quote
Old 06-22-2006   #2 (permalink)
Favorite Bike: 1995 Triumph Speed Triple
I shift without the clutch every now and then on longer rides when I'm lazy.
The only ill effect I can think of (assuming your not clunking and grinding gears while shifting) it a little more stress on the lever itself.
Other than that I'm not aware of any. Correct me if I'm wrong?
Travis
Albany, NY
tealetm is offline   Reply With Quote
Old 06-22-2006   #3 (permalink)
Favorite Bike: '98 Legend TT
Other Motorcycle: 1969 BSA Starfire
Extra Motorcycle: prev. '07 Scrambler
Clutchless UP shifting is fine if done correctly. Clutchless DOWN shifting,however, will likely wreck your your gearbox!
Alan.
Bikes?. . .I love 'em all, especially Triumphs
AlanFJ is offline   Reply With Quote
Old 06-22-2006   #4 (permalink)
+1
Dont use the clutch much going up but always down.
Dobie
Dobieman is offline   Reply With Quote
Old 06-22-2006   #5 (permalink)
Has anyone reversed the shift pattern on their Triples? On the new one it looks like you just need a longer linkage rod which would enable you to turn the piece connecting the rod to the transmission output shaft upside down. Has anyone done this and is it that easy?
If you don't have $10K in credit card debt you aren't really trying.
sabocat is offline   Reply With Quote
Old 06-22-2006   #6 (permalink)
Dobieman, that's real interesting. I've never had much success with shifting DOWN clutchless, I was taught, admittedly back in the 1960's, that down changing was a bad thing, (for the gearbox). Maybe my gear shifting is not, erm.... subtle enough!
Alan.
Old 06-22-2006   #7 (permalink)
Ooops just reread your posting,Dobieman, think I got the wrong end of the stick!
Alan.
Old 06-22-2006   #8 (permalink)
Read this...Art of speed control
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 06-23-2006   #9 (permalink)
rasbro
[quote]
i would not swear to it, but i pulled this off the other day and put it back on incorrectly, i think i had it set up to race-shifting, so it should be that simple if you decide to try it...
Old 06-23-2006   #10 (permalink)
other than for 1st and 2nd i generally do clutchless up shifting and occasionally down shifting- it's hasn't affected my gearbox yet w/45,000 miles. It's generally a good idea to tap the clutch along with the throttle 'blip' on downshifting, although if you blip the throttle quickly on the downshift w/o the clutch you won't kill your gearbox.
mbeebe900 is offline   Reply With Quote
Clutchless shifting jfenton Twins Technical Talk 34 08-28-2007 01:23 PM
Clutchless shifting BlackBeauty Sprint Forum 17 07-06-2007 03:51 AM
Clutchless shifting TOMKRILL Twins Technical Talk 11 05-25-2007 01:09 PM
clutchless shifting? nakedlover Speed Triple Forum 21 04-28-2007 11:47 PM
Clutchless shifting? Speed Triple Forum 11 08-02-2004 02:24 AM
