ShopTriumph.comMotorcycle.com Classifieds!SportbikeTrackGearMotorcycle.comBikeBanditRacerPartsWholesaleAdvanstarMotorcycleShowsTrident-Exhausts.com
RacerPartsWholesale
Old 06-21-2006   #1 (permalink)
grunt11b40x
ok calling all S3 gurus, my baby has developed this PSSssT sound at idle, and the rpms drop, but cruising speed it does not do it. it's almost as if the injector hickups or a pop in the intake. any ideas, or fixes please help a brother out .
Grunt
Old 06-21-2006   #2 (permalink)
Favorite Bike: '01 Speed Triple
Check your header mounting nuts for tightness. sometimes all it takes is to snug those down to get rid of the pssst noise.
Speed3 is offline   Reply With Quote
Old 07-25-2006   #3 (permalink)
beemer_dog
Grunt
Were you able to fix problem. Mine does exactly the same and I have no idea where to start.
Old 07-25-2006   #4 (permalink)
Hey SFC,
I have the same problem with mine. It doesn't really affect the perfromance any but it is a bit concerning. Tell me if tightening the header nuts works.
By the way, 11b40x, I was an 11b20v. Welcome, brother.
:2guns:
[ This message was edited by: Calitriple on 2006-07-25 15:50 ]
Calitriple is offline   Reply With Quote
Old 07-25-2006   #5 (permalink)
psssstttt sounds like a VAC leak...there's a few connections on these bikes...just not sure how loud it would be if they broke loose...
vac leaks would def affect idle
Mesoam is offline   Reply With Quote
Do you think this might be the problem? screamingearth Hinckley Classic Triples 9 08-04-2007 08:39 AM
Do I have a problem quagmire Classic, Vintage & Veteran 7 07-18-2007 11:37 AM
I had the same problem. etachell Speed Triple Forum 0 07-13-2007 11:39 AM
New 05 S3 problem SprinklerHead Speed Triple Forum 5 08-05-2005 10:31 PM
05 S3 Problem Rama Speed Triple Forum 15 04-23-2005 12:04 PM
