Actually, unplugging the battery means you'll have another fault to clear. Not to worry, though. For a transient sensor outage (which is all this amounts to) simply start and run the bike normally for a few days. After about three full startup and shutdown cycles, the light will extinguish-- assuming all the sensors are, in fact, now plugged in properly and all the connectors are making good contact.
John
