Old 06-20-2006   #1 (permalink)
I just got my Rizoma black break reservoir. Now, how do I replace the Tupperware one with this nice new Rizoma one? What is the best, least messy way to remove the break fluid and what are the tricks to adding the fluid back and removing the air? Thanks!
Chris
SlackCat is offline   Reply With Quote
Old 06-20-2006   #2 (permalink)
Easy - plenty of clean rag wrapped around bottom of reservoir to soak up spills. Keep cap on Tupperware reservoir - undo mountings and turn upside down (so spout is uppermost) Disconnect hose at reservoir end only and keep open end up (so fluid doesn't come out), trim hose with sharp blade as necessary, connect new reservoir, fill up with fluid and squeeze pipe repeatedly until no air bubbles can be seen, top up with fluid and put cap on. Position reservoir where wanted and tighten up fixings - job done - looks much better than original. Rear reservoir is cool too!!
oldmanrandall is offline   Reply With Quote
Old 06-20-2006   #3 (permalink)
Favorite Bike: Speed3 -09
Syphon the fluid out from the reservoir & rubber hose with a syringe from your local drugstore. That way you do not necessarily have to do a full brake bleed, just slap the new reservoir on and top it up.
Just remember not to pull the handle while there is no fluid as that will pump air to your brakelines.
Martin_R is online now   Reply With Quote
Old 06-20-2006   #4 (permalink)
Thanks! That seems much easier than I thought.
Reservoir Screws BigVinny Hinckley Classic Triples 2 09-30-2007 03:21 PM
brake reservoir cafecruzin Club Cafe 10 05-08-2007 06:21 PM
Brake reservoir skeeterbarnes Club Cafe 28 11-14-2006 05:54 PM
Can't get screw to break on brake fluid reservoir svanos Hinckley Classic Triples 12 10-05-2006 10:37 AM
Triumph break-in vs. Motoman's break-in? Triumph SuperSports 3 07-14-2004 06:58 PM
