Hey all, I just put an arrow exhaust system on my 06 S3 and took it to the dealer for the off road map. Now my low fuel light is on all the time. The dealer tried another map to no avail. Any ideas?
[ This message was edited by: FishandChips on 2006-06-20 05:06 ]
Mine did exactly the same when i had the TORS fitted! Turned out they had put the Sprint ST map on by mistake. Checked it, changed it, sorted it! If its not that there have been some problems with the float inside the tank.
No, as soon as he plugged in his terminal it showed ST. Went straight back in to the menu and loaded the correct map for the TORS. He called Triumph Technical Dept and they had heard of this happening before.
On 2006-06-20 11:24, rckrzy1 wrote:
Of coures not to over the look the obvious , you are not
LOW on fuel are you ?
No not low on fuel...I stopped in the dealership today and apparently Triumph just released a new map yesterday that corrects this very error. Should have it in Thursday and will report back. :upthumb:
I think this might actually be the culprit. He said that the map was the wrong one and that the new one will make more power. Sounds like they found the right one.
