i can try blowing air through the breather lines...not sure how anything would get in there....as i put a plastic bag over the tips and taped it off while the tank got painted, but can't hurt to check. haha, unless something fell in that i used to protect it...not likely.
not sure which tipover valve u mean? where is this located? i can check the service manual tonight (if it shows this). will have to take closer look. the actual two nipples that i removed from tank are identical are they not? either way, i had labeled them so they should have went back on same. breather hoses also labeled but certainly worth a double check. i'll try removing both. problem is intermittent, other than a slower start so not sure if this will tell all unless it fires up immediately with noticeable difference.
should not be any paint in the tank and it looked clean. this was thoroughly taped off. some small amount of dust in there maybe from pre-taping, maybe, not sure it would result in this behavior...i mean...the filter should catch any minor debris right? i could pull the entire cluster out but this would be last resort as quite a pain in arse.
"Or some rubber grommet around the breather holes around the filler opening mounted a bit funny and as a result it is blocking the hole"
u mean the little black rubber washers around the breather nipples attached to tank (there are 2)? i put new washers on. not sure how these would end up covering anything. i could have overtightened (oops no torque wrench though i have one now) but i'm not sure if they could even expand so much as to cause a problem?
thx for tips. will check all this. let me know if ya have more details per the questions above so i can ensure i am checkin all the right things.
jeff
Have you tried blowing air through the two breather lines coming from the tank to check they are clear?
Do you still have the tipover valve on the other breather? Is it mounted exactly vertical? Are you sure you mounted the breather lines the right way around and did not accidentally reverse them or mount the one with the valve upside down? You can make diagnosing easy by temporarily taking the lines off and try if it makes any difference to the starting.
Other than a problem with the lines or some foreign stuff (paint?) clogging the fuel filter is all I can think of, if you did not touch anything else. Or some rubber grommet around the breather holes around the filler opening mounted a bit funny and as a result it is blocking the hole.
