ShopTriumph.comSportbikeTrackGearAdvanstarMotorcycleShowsBikeBanditMotorcycle.com Classifieds!RacerPartsWholesaleTrident-Exhausts.comSpringfield ArmoryMotorcycle.com
RacerPartsWholesale
Old 06-19-2006   #1 (permalink)
Does anyone know if you can "just" take the stock sprocket straight off without removing the wheel? (on an 06 1050) Looks like you can just take it straight off once you have split the chain...
Do you have to remove the domed cover first??
Anyone know the torque settings for those nuts???
Cheers in advance...
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
Old 06-19-2006   #2 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
Yes, you can remove the sprocket by loosening the six bolts on the sprocket edge. Nothing else will come loose, so no need to support the bike on a rearstand or similar. Do not remove or loosen the cust drive unit (the black dome) that sits in the middle - so leave the big nut alone.
Edit. The correct sprocket bolt torque is 33Nm.
[ This message was edited by: Martin_R on 2006-06-19 06:17 ]
Martin_R is offline   Reply With Quote
Old 06-19-2006   #3 (permalink)
Yes, just loosen the chain and the rear sprocket can be replaced without removing anything else. No need to split the chain. Don't know the torque right off hand, it's in the manual at home.
littlefield is offline   Reply With Quote
Old 06-19-2006   #4 (permalink)
Sounds like even I can do this !!! cheers
Old 06-19-2006   #5 (permalink)
Hey gstar.... what kind of sproket and chain did you get... also what did you get them for? I am in the market so i have been looking for a good deal..
thanks
Desmo is offline   Reply With Quote
Old 06-19-2006   #6 (permalink)
Hey Gstar did you get a new front sprocket or just the rear?
MD05S3 is offline   Reply With Quote
Old 06-19-2006   #7 (permalink)
Got just a rear...
Demon Tweeks
Got it from them.. very cheap too !!
Old 06-19-2006   #8 (permalink)
On 2006-06-19 09:05, gstar wrote:
Got just a rear...
Demon Tweeks
I make it a habit to always replace both sprockets and chain as a set. Unless your front sprocket is virtually new it is a false economy to reuse it. If it is even slightly worn it will accelerate the wear on the chain and rear sprocket.
dr_gallup is offline   Reply With Quote
Old 06-19-2006   #9 (permalink)
Well it's only 4 months old.. should be fine.. but good tip... !! I have put the bad boy on.. seems to have made quite a bit of difference but not giving it loads until it has done that initial stretch... maybe wish I had gone down one on the front as well for that ultimate different feel.. worry it might be a little un-rideable with that !! need to get the speedo healer too as it's over reading by approx 10% now.. thought I am not quite sure how much...
Old 06-19-2006   #10 (permalink)
Your 42 to 44 sprocket change increased your speedo error by 4.5%. Since I believe the stock speedo error is about 7% you are over 10% now.
I never got around to checking my stock speedo vs GPS so I can't confirm the 7% number but that is what others have posted.
new sprocket, new chain? metasac Twins Technical Talk 14 09-22-2007 02:14 AM
Chain lengh with a 44T rear. Limey Speed Triple Forum 11 01-13-2007 03:51 AM
Oh ya... 44t sprocket... a MUST do... Geof3 Speed Triple Forum 64 08-27-2006 04:22 AM
18 tooth front sprocket arrived... bgaz Twins Technical Talk 3 07-29-2006 09:19 PM
largest rear sprocket w/out new chain? rustbucket Triumph SuperSports 1 04-23-2006 07:52 AM
