Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Old 06-18-2006   #1 (permalink)
Guys,
Looking for aftermarket rear sprockets for my S3. I want to go up two but can't find a US dealer/distributor that has them. I know Renthan does one, but I can't find anyone that sells them. Are the 05-06 compatable with any other years?
Also, I've noticed on the Buells the rear "sprocket" is HUGE... Why is ther such a difference in gearing with a belt drive?
Isn't that Special...
Geof3 is offline   Reply With Quote
Old 06-19-2006   #2 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
All recent single side swingarm sprockets are interchangeable. Not all of them have the decorative holes of the recent ones, though.
But I have not found anyone who makes 44s for the 955 either. Which is kind of a shame as the 44 is the natural choice when running the stock chain with a bit tighter gearing as the 44 fits in nicely.
So Renthal it is if you prefer the 44 like I do. A 45 might fit also on the stock chain, but have not tried this one so can't say for sure.
Martin_R is offline   Reply With Quote
Old 06-19-2006   #3 (permalink)
rasbro
www.sprocketspecialists.com sent me one for my '05 speed triple.
they don't list it specifically for the '05 but it is a straight bolt on.
same part number as earlier models.
2695-44 cost $62.99
the 44 fit on with no problems with 7000k on the bike. could possibly have squeezed on the 45...
Old 06-19-2006   #4 (permalink)
Geof3 i have done an extensive search for this very item and the best place i came up with is this place.
B & C Express
They have them in stock and ready to ship. The item numbers you want are.
43T 389-530-43HA
44T 389-530-44HA
45T 389-530-45HA
The Links above are for a 05/06 Sprint as they do not have the S3 listed but they are the same item.
<html><body><input src="http://img.villagephotos.com/p/2006-4/1169863/S3JACK.gif"type="image"><input src="http://img.villagephotos.com/p/2006-4/1169863/ratnetver.jpg"type="image"
Sparti is offline   Reply With Quote
Old 06-19-2006   #5 (permalink)
Sparti,
Checked them... They don't sell to the US... :???:
Old 06-19-2006   #6 (permalink)
Did you try demon tweeks?? www.demon-tweeks.co.uk
My renthal fitted perfectly...
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
Old 06-19-2006   #7 (permalink)
Gstar, can you provide a part number?
Old 06-20-2006   #8 (permalink)
The part number is the same as the B&C number...
389-530-44HA
I had to ring them in order to get it sent.. it appears they don't like to deal with specifics on their website.. excellent service mind..
renthal
[ This message was edited by: gstar on 2006-06-20 01:45 ]
Old 06-20-2006   #9 (permalink)
Phoned them up and they do deliver worldwide !!
Old 06-20-2006   #10 (permalink)
Some food for thought before you choose what size sprocket to get. I personally have decided to go with the 46T rear. I went one down on the front and found that great but went back to standard as some have said that a smaller sprocket on the front can cause the chain to rub on the swing arm. Anyway hope this helps.
Rear Sprocket - 42 (standard)
Gearbox Sprocket - 18 (standard)
Speed MPH & 4000 RPM
26.44
37.11
46.77
55.97
62.67
67.28
Top Speed 153.07MPH @ 9100 RPM
Rear Sprocket 42 (Standard)
Gearbox Sprocket 17
24.97
35.05
44.17
52.86
59.19
63.54
Top Speed 144.56MPH @ 9100 RPM
Rear Sprocket 44
Gearbox Sprocket 18 (standard)
25.24
35.43
44.64
53.43
59.82
64.22
Top Speed 146.11MPH @ 9100 RPM
Rear Sprocket 45
Gearbox Sprocket 18 (Standard)
24.68
34.64
43.65
52.24
58.49
62.80
Top Speed 142.86 MPH @ 9100 RPM
Rear Sprocket 46
24.14
33.89
42.70
51.11
57.22
61.43
Top Speed 139.76 MPH @ 9100 RPM
Rear Sprocket 45
Gearbox Sprocket 17
23.31
32.72
41.23
49.34
55.24
59.31
Top Speed 134.92 MPH @ 9100 RPM
Couple of questions.. GenIIIMrDuece Speed Triple Forum 2 10-02-2006 12:54 AM
Help please on a couple S3 questions... kwajazz Speed Triple Forum 5 09-29-2006 02:27 PM
Couple of questions clive955 Tiger Chat 4 01-09-2006 12:54 PM
Legend gearing questions triumph900 Hinckley Classic Triples 3 04-07-2004 12:06 PM
A couple of new RS questions Solace Sprint Forum 15 03-11-2004 08:48 PM
