Trident-Exhausts.comMotorcycle.comBikeBanditAdvanstarMotorcycleShows
Old 06-18-2006   #1 (permalink)
I just searched for every combination of "reflector" "remove" "residue" and "fork" I could think of and I can't believe I found nothing....So I'll ask. What is the name of that ***** that will remove the gum residue from the forks that the reflectors leave behind?
http://www.grahamcrosby.com
To do is to be. -Descartes
To be is to do. -Voltaire
Do be do be do. -Frank Sinatra
GrahamC is offline   Reply With Quote
Old 06-18-2006   #2 (permalink)
bsmith222's Avatar
Goo Gone
bsmith222 is offline   Reply With Quote
Old 06-18-2006   #3 (permalink)
On 2006-06-18 15:48, bsmith222 wrote:
Goo Gone
Thank you THANK YOU!! That was driving me crazy! I'll run out and pick some up....
Old 06-18-2006   #4 (permalink)
Nothing fancy, but I found that kerosene worked just fine...
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
Eldercanuck is offline   Reply With Quote
Old 06-18-2006   #5 (permalink)
Goo-gone Goof-off and all of their fellows are essentially naphtha. Otherwise known as "Lighter fluid", and available everywhere. Naphtha is a light weight, quickly evaporating, mild solvent that doesn't attack plastics and other delicate materials very badly. You can buy it by the gallon for little more than a tiny bottle of Goof-Off.
crashmasterd is offline   Reply With Quote
Old 06-18-2006   #6 (permalink)
I got mine off w/ WD-40.
AlaskaS3 is offline   Reply With Quote
Old 06-18-2006   #7 (permalink)
What AlaskaS3 said... WD-40
the good part is, you probably already have it in your garage, No need to go shopping.
Few things are harder to put up with than the annoyance of a good example.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Hairball is offline   Reply With Quote
Old 06-18-2006   #8 (permalink)
HiVel's Avatar
My Norweigan Elkhound licked mine off and then ate the front tire for desert!
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Old 06-19-2006   #9 (permalink)
WD40 and Elbow Grease Works.......
RedNeck-Rat
RedNeck-Rat is offline   Reply With Quote
Old 06-19-2006   #10 (permalink)
+1 on the WD-40
TonUp wrote:
Are you a Hooligan? I know that Corners and Cheapbastard are for sure and so am I!!!
http://i56.photobucket.com/albums/g1...-hooligans.jpg
corners is offline   Reply With Quote
gunk on valves?? gm16sw Twins Technical Talk 18 11-19-2007 07:51 PM
Headlight reflector bigred900 Hinckley Classic Triples 7 06-27-2007 07:52 AM
Reflector Removal Q Black23 Twins Technical Talk 16 05-19-2007 02:21 AM
Cleaning the chain with Gunk Kem770 Hinckley Classic Triples 23 10-09-2006 07:51 AM
anyone use GUNK on thier bike? dazco Modifications & Workshop Talk 5 08-25-2005 10:47 AM
