Old 06-15-2006   #1 (permalink)
mukymuk
My 05 S3 is just now hitting about 9K and has recently started hesitating at low RPM. What I mean is that if I throttle it up from idle to, say, 4000 RPM it acts as if it's missing. After a second or two it gets over it's trouble and revs on up fine. At that point, if I suddenly let off the throttle it will idle very low for a couple seconds and sometimes die. If I do that a few times I can smell gas.
After the bike is *completely* warmed-up it behaves fine. I first noticed this behavior about a 500 miles ago and it has steadly gotten worse.
So I have some suspicions--fuel filter, airfliter maybe? I love riding, but my motorcycle diagnostic skills are poor, I must admit.
Shawn
Old 06-15-2006   #2 (permalink)
Limited Access
did you have the 6k service
Limey is offline   Reply With Quote
Old 06-15-2006   #3 (permalink)
mukymuk
Yes. I've had no problems at all until recently.
Old 06-15-2006   #4 (permalink)
Limited Access
if you have not adjusted the throttle latley, change the plugs.
the reason I mention throttle is if over adjusted, screws up the ecu. change the plugs anyway. just my opinion
[ This message was edited by: Limey on 2006-06-15 21:22 ]
Winter-time is the Mod-ing Time Raindogs Twins Technical Talk 12 01-29-2008 01:08 PM
long time lurker,1st time poster gaptooth grin Twins Talk 9 07-29-2007 09:14 AM
Triumph sucks big time. Will buy Honda next time. drainbamage Speed Triple Forum 20 06-19-2007 11:39 PM
new to ST maintenance vwvectors Sprint Forum 1 12-04-2004 11:28 AM
Do it yourself maintenance rodneybrown Sprint Forum 3 11-28-2004 01:28 PM
