G'day Tim,
I am looking at my service manual - the section on Throttle Body Balancing, and I quote:
"The throttles cannot be balanced using equipment to measure vacuum in each throttle. Instead, the Triumph diagnostic tool must be used."
It goes on to describe connection of the diagnostic tool to the throttle bodies, inserting exhaust extraction hoses to the silencers, then you navigate the menus till you find 'adjustments', select 'balance throttles', then you make adjustments to the throttle adjusters until the word balanced appears on screen.
So without access to the diagnostic tool it appears that you can't do it yourself.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
