Motorcycle.comRacerPartsWholesaleSpringfield ArmoryBikeBanditAdvanstarMotorcycleShowsSportbikeTrackGearTrident-Exhausts.comMotorcycle.com Classifieds!
Old 06-13-2006   #11 (permalink)
Know what you mean Celt.. I have the same issue... it sure feels good.. really happy with it .. will get it together for you guys.. end of the week though..
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
Old 06-13-2006   #12 (permalink)
On 2006-06-13 12:14, goode96 wrote:
yeah...is there like a simple plug and chug formula for suspension setup? I'm kinda tiny...about 135 pounds...how do i go about adjusting the bike for my tiny @ss?
Dude, my leg weighs that much.... I think the bike is oversprung for your weight. I think you would need a totally different spring setup, front and rear.
What bugs me about the S3 sus is the "nebulous" turns thing. Why not make the thing with solid clicks? When I get home from sunny Cozumel, I'm ordering an Ohlins rear for my bike... The front sorts fairly well, but I'm not sure about the progressive springs totally, overall it's ok. The rear on the other hand seems totally useless. One setting it wallows all over the place with no feel. One little adjustment, stiff as a board on bigger hits. In CO I need something a bit more compliant as MOST of the roads I drive would be considered B roads or even C roads in the UK... Can make for some "interesting" cornering. Haveing a low and high speed damping adj. would be BEAUTIFUL... :-D
Isn't that Special...
Geof3 is offline   Reply With Quote
Suspension Setup RoadBuilder Sprint Forum 19 06-18-2007 10:58 PM
Suspension setup- Static Sag greenman Tiger Workshop 1 07-09-2006 11:59 AM
Suspension setup advice needed dawgfan Twins Talk 4 06-11-2006 03:21 PM
Suspension setup for Adventurer? Help! Brooke Hinckley Classic Triples 1 03-30-2006 02:24 PM
Speed Triple Suspension Setup hooligan2001 Speed Triple Forum 1 07-13-2004 10:39 AM
