BikeBanditShopTriumph.comTrident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShowsSpringfield ArmorySportbikeTrackGearRacerPartsWholesale
TriumphPerformanceUSA
Old 06-12-2006   #1 (permalink)
I am getting ready to buy a 2002 speed triple and I was wondering if there are any special tools necessary to install a new set of sprockets and a new rear tire? Thanks in advance.
PROMOD1385 is offline   Reply With Quote
Old 06-12-2006   #2 (permalink)
The rear tire requires a BIG socket. I think it's 46mm, ( 1-13/16 ?) but somebody check me on that. The Sprocket is fairly straight forward. Any metric socket set will have all you need, unless you need to split the chain. There's a tool for splitting the chain that makes life much easier. Oh, and a couple of hex keys and the spanner from your tool kit for adjusting the chain, and a pair of pliers.
If you are going to change the front sprocket then you will need a 36mm socket as well.
If you are changing the rear sprocket you may need a longer or shorter chain, and it's usually a good idea to replace them anyway if there's quite a few miles on it.
crashmasterd is offline   Reply With Quote
Old 06-13-2006   #3 (permalink)
46 mm
TrackerOldGuy is offline   Reply With Quote
Old 06-13-2006   #4 (permalink)
nyburner's Avatar
1-13/16 is the standard size.
You'll also need a rear SSSA paddock stand. If you don't already have one then:
www.pitbull.com
www.skykingproducts.com
www.oboyessen.com
nyburner is offline   Reply With Quote
Old 06-13-2006   #5 (permalink)
HiVel's Avatar
A really good investment is a center stand from Mo-Tech (German) available on the net.
Anything worth doing is worth doing to excess!
2007 Tiger "Old Blue"
HiVel is offline   Reply With Quote
Special Tools for 2005-7 S3 leeshelford Speed Triple Forum 2 10-29-2007 11:08 AM
Special tools for Ign adv removal Ahobie17 Classic, Vintage & Veteran 2 08-06-2007 05:58 PM
Special Service Tools. POPPE Twins Technical Talk 15 12-01-2006 08:34 PM
Special Tools??? cheapbastard Speed Triple Forum 9 02-24-2006 07:07 PM
Special tools for case splitting? mattyg Classic, Vintage & Veteran 4 09-02-2005 10:03 AM
