Littlefield,
No, I haven't gotten it figured out yet. I understand your comment re removing the sprocket. But the manual is clear that isn't necessary. Moreover, once you get it all set to TDC so all the valves and pistons are where they need to be and you don't want to be turning anything anymore, you don't have access to both of the bolts holding the spocket to the shaft.
Still looking for any help.
