Removing valve cover - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Ontario TourismHonda PowersportsNew Bonneville
Old 06-10-2006, 02:12 PM   #1 (permalink)
Favourite Bike: '02 Sprint
I'm all set to check my valve clearances at their 12,000 checkup and am stopped at how to break the seal on the valve cover.
Air box is off, coils removed, etc. All six bolts holding the valve cover are removed. But I can't pull the valve cover off. There's nothing to grip and the manual gives a strong warning against trying to pry it off (i.e. with a screwdriver at the gasket joint).
Any advice is welcome.
PaloAlto is offline   Reply With Quote
Old 06-10-2006, 05:01 PM   #2 (permalink)
I have not taken mine off yet. Having said that , the manual
states" 10. Ease the water hoses to allow the cover to be removed from the left side of the motorcycle." I don't know
why/how that the water hoses make a differance but maybe
they are giving us a hint.
Let us know how it goes. ( some car manifolds need a slight wack from a rubber malet----but don't say i told you to
do it)
TrackerOldGuy is offline   Reply With Quote
Old 06-10-2006, 06:30 PM   #3 (permalink)
Tracker,
It took quite a few gentle wacks to break the gasket seal. Once that was done, actually removing the cover was easy. I don't know why the manual says ease it out past the radiator hose - you can lift it pretty much up and out.
Valve-shim swapping without removing the cams SpitfireTriple Daytona Deliberations 19 10-03-2008 07:51 PM
Removing the instrument cover Lom Speed Triple Forum 3 06-17-2006 04:27 PM
Removing valve cover PaloAlto Sprint Forum 3 06-12-2006 08:04 AM
valve adjust w/o removing cams??? dazco Twins Talk 12 12-20-2005 03:54 PM
Removing cam cover Masscotte Maintenance & Workshop Talk 2 12-09-2002 02:06 PM
