Motorcycle.comTrident-Exhausts.comSpringfield ArmoryRacerPartsWholesaleAdvanstarMotorcycleShowsSportbikeTrackGearMotorcycle.com Classifieds!ShopTriumph.comBikeBandit
Old 06-07-2004   #1 (permalink)
What's happening here:
Warm up S3 to about 50C.
Take off to desired destination.
Coolant now reading 60C.
Coolant now reading LO momentarily and returns to normal operation.
Engine Light comes on.
Happens repeatedly and is annoying, light goes out after 3 warm up cool down cycles and repeats.
Is this a coolant sensor fault or a fault in the CPU?
Anyone else had similar problems? Will take to dealer to have it sorted soon.
James
britishbulldog is offline   Reply With Quote
Old 06-07-2004   #2 (permalink)
Favorite Bike: tied between my '02 S3 and my '06 R3
Other Motorcycle: Bonneville
had the same prob on mine. make sure your fan is operating right. if it is put it on a center stand and top off your coolant. shoud correct the prob.
That which doesn't Kill you will only require brief Hospitalization!!!!
felixEOD is offline   Reply With Quote
Old 06-11-2004   #3 (permalink)
Yeah everything seems to be working fine...cooling fan etc except for problem mentioned in previous post. The other morning it happened again, I felt a surge of acceleration, the engine had returned momentarily to auto choke and then resumed to normal operation this is when the engine light illuminates!
Old 06-14-2004   #4 (permalink)
hey man,
i got no ideas on the surge thing then the light coming on. you need to get it on a computer to find out what the codes are.
good luck
Coolant stains on coolant hose? moyster Speed Triple Forum 3 10-09-2007 12:02 PM
Reading Test mglemans86 Biker Hang-Out 5 04-17-2007 10:14 PM
Brown coolant??? Coolant change?? Suncoast Sprint Forum 8 02-05-2007 12:51 PM
Flushing 01 coolant, no manual? coolant bubbles after use! speedtripleride Speed Triple Forum 1 05-21-2006 12:53 PM
reading material CCR Modifications & Workshop Talk 7 04-09-2006 12:32 PM
