On 2006-06-05 20:36, BulldogHooligan wrote:
Has anybody else here installed the MD front blinkers ?
Also, it looks like I need to use a separate load block for the front blinkers.
I have the kit. Thankfully I am an engineer with a graduate degree, loads of patience, and a family member who is fluent in Italian to decipher the instructions. I almost sent the thing back but it got personal.
Notes:
- you don't need the second block. Run it from a single block and splice it into the original wiring for the OEM front signals. That is the trick. I keep the block on the top of the eliminater between the IMHO weak rear light mounting contraption.
- don't get any of the lights near water unless you wish rain clouds to form under the plastic.
- continually check the set screws for the turn signals as they loosen but are so flimsy that I don't want to use loc-tite
- your mounting screws should be OK.
- they will limit your selection of exhausts as the rear signals are in a weird position.
- plate light works on the running light connection from OEM.
Having said all that, the finished product does look very good. Good Luck!
I can put some pictures together if you wish.
[ This message was edited by: MrBiff2You on 2006-08-18 16:28 ]
