On 2006-06-03 15:56, TonUp wrote:
Another quick way to check you speedo error is to find one of those RADAR Display units on the side of the road that flash your speed, Try it at different speeds, ex. on a 65 mph zone try it at 60mph, 65mph and then at 70mph, it should give you a pretty good idea how accurate your speedo is.
Ton Up!
and then try a pass at 120!!! :lgh: Yeah, it's a known fact that most all speedo's have errors. But no matter, if my speedo says 149, that's how fast I'm telling everyone I was going! I wished my 99 R1 had a top speed memory, I did alot of top speed runs with that bike(stupid in hindsight!), and finally hit 190mph!!! Sixth gear taching a little over 12k rpm, didn't hit the revlimiter, but it was right at it, because it kicked in right around 12,500. :wink:
