BikeBanditShopTriumph.comTrident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShowsSpringfield ArmorySportbikeTrackGearRacerPartsWholesale
TriumphPerformanceUSA
Old 06-01-2006   #1 (permalink)
What size are the fork tubes on a Speed Triple? I need a dual headlight bracket that will fit 43m/m fork tubes
barryd is offline   Reply With Quote
Old 06-01-2006   #2 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
The 2005-2006 Speed Triple
43mm USD forks with dual rate springs and adjustable preload, rebound and compression damping
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Old 06-01-2006   #3 (permalink)
Thanks Tonup. Do the headlight brackets mount to the fork tubes?
Old 06-01-2006   #4 (permalink)
No... the headlight mount is a frame mounted piece and also mounts the instrument panel...
Isn't that Special...
Geof3 is offline   Reply With Quote
Old 06-02-2006   #5 (permalink)
Thanks, that kill that idea!!
what size are the clipons (fork tube diameter) on 05+ S3? salty_scuff Speed Triple Forum 9 08-02-2007 09:54 AM
Rear Tire Inner Tube Size Tbird95 Hinckley Classic Triples 1 03-06-2007 05:37 PM
Tube size vol245 Twins Talk 0 04-10-2006 03:12 PM
AI tube spanner size request DrBeast Twins Talk 2 03-02-2006 08:48 AM
What size tube to buy for brake bleeding? 00wabbit Hinckley Classic Triples 2 11-05-2004 05:47 PM
