RacerPartsWholesaleSportbikeTrackGearAdvanstarMotorcycleShowsTrident-Exhausts.comSpringfield ArmoryShopTriumph.comBikeBanditMotorcycle.com Classifieds!
Old 06-01-2006   #1 (permalink)
Im still trying to sort out this problem with my s-3.Three weeks ago my fuel regulator went out .My bike would idle but kept stalling out every time I rolled on throttle,kinda simulating running it out of gas....Could this have taken out fuel pump?Ive ridden bike three times since it was fixed,but as I posted earlier the other day it just quit and wouldnt start.The next day it would however,intermittent problems are hard to diagnose!
[ This message was edited by: woodenindian on 2006-06-01 09:46 ]
woodenindian is offline   Reply With Quote
Old 06-01-2006   #2 (permalink)
I am a bit confused between the title of this post and the contents. Did you run the bike out of gas or did the pressure regulator fail or both? Running out of gas could conceivably burn out the pump because they are cooled by the gasoline. However, they usually survive the occasional dry run. A failed pressure regulator should not take out the fuel pump.
dr_gallup is offline   Reply With Quote
Old 06-01-2006   #3 (permalink)
Stating the obvious but have you checked for tank vacuum? Seems a common prob on the S3. Just open the fuel tank, when the engine refuses to run/runs badly, and if air whooshes in then you have a stuck/non vertical tip over valve or a kinked/blocked breather pipe.
Avi8or is offline   Reply With Quote
Fuel Pump crackerkorean Sprint Forum 10 09-21-2007 11:59 PM
'02 st fuel pump tojohn Sprint Forum 8 11-17-2006 11:24 AM
Help! Fuel Connector/Fuel Pump LeDude Speed Triple Forum 2 09-18-2006 10:58 PM
Fuel Pump MVP44 Sprint Forum 6 09-03-2006 12:56 PM
fuel pump and fuel injectors speedmerlau The Rocket Science Forum 5 11-01-2005 02:12 PM
