Old 06-01-2006   #1 (permalink)
Anybody have some more information on the subject?
I found information on the LSL with 1" rise working with quite a few modifications to the lights and gauges.
The Woodcraft clipons are too low. They look like they are just shy of being functional that low. The 1"-2" risers I've seen look perfect, but has anybody found a kit or way of mounting them easily yet?
odium is offline   Reply With Quote
Old 06-01-2006   #2 (permalink)
Hi
I have clip-ons with 60mm rise from them:
http://www.lucas-bikersworld.com/en/...token/32486091
and am very happy with them.At first their system looks weird(adaptor sleeve) but it works for almost a year without problem.I had to play with them so it didn't touch the speedo but by 1mm it is ok.
Cheers
speedytriple69
speedytriple69 is offline   Reply With Quote
Old 06-01-2006   #3 (permalink)
I had the Woodcrafts but I'm now using Tommaselli adjustable clip-ons that have a bit of rise and are adjustable in every direction.
Tommaselli clip-ons
There are pix in my album.
good luck,
Zohar
zmann is offline   Reply With Quote
Old 06-01-2006   #4 (permalink)
I had a set of "Variobars" from Gilles Tooling on my Aprilia. Fully adjustable and you can get risers up to 100 mm, I believe. Excellent quality, but pricey.
On the cheap side of things, how 'bout a clubman style bar. That'll give you the look and be about the height you're looking for all for as little as $75.
gr8shandini is offline   Reply With Quote
Old 06-01-2006   #5 (permalink)
zmann, can you use all the standard cables? Did the CRG mirrors bolt right on? Are you having or have you had any clearance issues?
The clubman bars would work, but has anybody gotten clubman bars to work on their s3? I am actually very interested in this option. They would look pretty decent in black.
[ This message was edited by: odium on 2006-06-01 18:30 ]
Old 06-01-2006   #6 (permalink)
Yep standard cables and no clearance issues once adjusted properly but these do take a little more than the usual clip-on finessing b/c they have more joints. Just check at steering lock in both directions before final torque (and watch out of the instrument cluster clearance and throttle cable tension).
Cheers,
Zohar
Old 06-01-2006   #7 (permalink)
What front blinkers are those, and what others would work similarly?
Old 06-03-2006   #8 (permalink)
Mine? I just grabbed some sticky-backed LP blinkers, spliced the wires, and stuck them on. Not sure which others work.
High Rise Bars on a Bonnie? rmak Twins Technical Talk 25 01-07-2008 03:07 PM
Spectacular Earth rise shots Tbirdnz Biker Hang-Out 9 11-15-2007 01:44 PM
getting a rise.. akenaten Twins Technical Talk 3 06-25-2007 03:00 PM
noticeable rise in compression Hammer101 Modifications & Workshop Talk 3 06-07-2006 11:54 PM
cant rise cause its snowing solution retro900 Club Cafe 3 01-21-2006 12:41 PM
