On 2006-05-31 10:56, Avi8or wrote:
Was wondering if loading that map would prevent the ECU from misbehaving if I removed the SAI and Cats.
That would be the current theory on t595.net, but no one has been able to give a definite answer.
Try and see? At worst the ECU will go into limp-home mode, but as you already must have some device to upload the maps you have the tools to clear the errors too. If an error is thrown a resistor is an easy addition if you pull the solenoid wire someplace a bit more accessible than the underside of the airbox.
20102 20100 1050cc Speed Triple with aftermarket exhaust with catalyst and secondary air injection
20103 20100 1050cc Speed Triple with aftermarket exhaust
I have compared these two in Tuneboy a while back and the fuel injection map, AF table and ignition map seem to be identical in every cell. So the conclusion would be that the differences are in the hidden program part. Maybe the latter map ignores the solenoid valve?
Wayne "the TuneBoy guy" McDonald said on t595.net that a non-SAI map should only be used with a blocked SAI as according to him with a non-SAI map the solenoid is open all the time. Sounds a bit strange to me, I would guess that the solenoid is closed by default, but Wayne is much more knowledgeable on these things.
