RacerPartsWholesaleSportbikeTrackGearAdvanstarMotorcycleShowsTrident-Exhausts.comSpringfield ArmoryShopTriumph.comBikeBanditMotorcycle.com Classifieds!
Old 05-29-2006   #1 (permalink)
Good afternoon, all.
I've come up with a bit of a problem.
Today I rode back from a short trip to play some basketball. It's about 93F here in St. Paul today, so it's pretty hot. The temp gauge while doing my inner-city riding was just above the low mark, since I'd been keeping moving. By the time I parked the bike, the temp needle was about par for the course - about half way up the temp gauge. I park it and shut it down, and the fan starts making this godawful clunking/whining noise. I, of course, worry about this, as I didn't hear the rush of air, and knew the fan wasn't actually turning.
So once the thing finally cooled down enough for me, I pull the radiator away and remove the fan. The fan is melted! Not the blades of the fan themselves, but the inner part of the fan that attaches to the metal fan motor plate! It apparently melted, then the whirring fan motor "smudged" the middle of the fan up! Ick. What a mess.
So my question to those whom may know:
I'm shopping a replacement fan, and found an aluminum Muzzy unit. They list parts for the following:
-1997-2001 Triumph Daytona
-1999-2002 Triumph Speed triple
-1999-2002 Triumph Sprint
All three fans are listed as the same part number.
None of these is specifically a part for my bike - a '97 Speed Triple.
Is it safe to assume that the seemingly universal Triumph part will also fit my bike? Does anyone have any experience with the aluminum Muzzy unit?
Thanks for the help!
Repeater is offline   Reply With Quote
Old 05-29-2006   #2 (permalink)
Favorite Bike: '01 Speed Triple
That Muzzy one sounds good. how Much? I have a friend who's fan went, and he found a replacement at Baxter Cycle, in Marne, Iowa for much cheaper than buying new. Baxter is a M/C salvage yard/dealer
Speed3 is offline   Reply With Quote
Old 05-29-2006   #3 (permalink)
Including 2-day shipping to me, the Muzzy fan would be about $55. Seems like quite a bit, but now I've got it in my head that I actually have to worry about fans melting! The fan itself is $36. I'm impatient, so I think I'd order it with some fast shipping...
Old 05-29-2006   #4 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Repeater, I can't help with the part number, but I can with prevention of it happening again.
I've had one go one me, then I blew the fuse another time. Both after riding on unsealed roads. The tar and small gravelly bits get kicked up and make their way into the cowling that holds the fan on the radiator, thereby preventing the blades from turning. The first time the fuse didn't blow, but the blades melted off the fan motor. The second time the fuse blew saving and fan damage.
Took off the fan unit and all this gravel and tar fell out. So I made a small cut-out in the bottom of the cowling to prevent stuff from building up in there again.
Good luck,
Mick
My Album
miker is offline   Reply With Quote
Old 05-29-2006   #5 (permalink)
That's a good tip, Miker! I will do that for a preemptive strike!
Old 05-30-2006   #6 (permalink)
Nice tip, Mick! I'll have to try that out while I've got the whole works apart and I'm awaiting my new fan.
I've ordered the fan from Muzzy's. I'll let you all know, just for the record, if it fits properly or if I need to modify it to work. I have a feeling, though, that it will probably work just fine.
Old 06-02-2006   #7 (permalink)
Just to close this down :
The Muzzy aluminum fan off their site does NOT fit the '97/'98 Speed Triple. It really only does fit the models listed. I gave it a shot, but the bolt holes are too far apart, and the fan's diameter is too wide. So, off to find another source for a T509 cooling fan!
If anyone happens to need an aluminum fan for T595/955i Daytona or a '99 to '02 Speed Triple, let me know! I'll let go of a nice fan for cheap!
part number help uniqueone Classic, Vintage & Veteran 5 09-12-2007 02:00 AM
Igniter part number? Panthermark Twins Technical Talk 16 09-13-2006 08:47 PM
Need a part number NinjaRAT Sprint Forum 2 08-23-2006 08:50 PM
Part number? j98sprint Sprint Forum 2 06-12-2005 02:08 PM
Part number? j98sprint Modifications & Workshop Talk 0 06-12-2005 09:00 AM
