RacerPartsWholesaleSportbikeTrackGearAdvanstarMotorcycleShowsTrident-Exhausts.comSpringfield ArmoryShopTriumph.comBikeBanditMotorcycle.com Classifieds!
Old 05-29-2006   #1 (permalink)
Regarding 13's response to zmann's engine starting problems,which is happening to me occasionally,when checking the oil do you screw the dipstick in to check the oil or just place it in until it rests in the hole.Know this may sound stupid but every other bike i've had with a dipstick i have had to screw it in to check oil but when i picked my bike up last year i did all the usual and checked everything and found it had about 500 ml too much oil in it.Rang dealer to see about dipstick and they didn't seem to know so i stuck with the screwed in method.Is this correct?
Bucket
Bucket
BUCKET is offline   Reply With Quote
Old 05-29-2006   #2 (permalink)
Hey Bucket,
I believe the dipstick should be screwed all the way home to check the oil level. I would be more than a little worried about the dealer if he does not know the answer to that one.
I am generally happy with my dealer, but after both the first and second service the bike was given back to me with the chain too tight. Now I try not to take anything for granted.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 05-29-2006   #3 (permalink)
The bike needs to be standing straight up with the dipstick fully seated. Not straight up on a rear stand. The easy way to do this is to remove the stick wipe and replace. Tip the bike up, set it down easily and check. I just lean over the left side and tip the bike up while I check it.
Isn't that Special...
Geof3 is offline   Reply With Quote
Old 05-29-2006   #4 (permalink)
Thanks fella's,thought it should be screwed in but just wanted to check.
Bucket :hammer:
Bucket
Dipstick stuck Ben Rawlinson T3 Sport / Touring Forum 5 01-31-2008 07:53 PM
Dipstick... Blockhead Tiger Workshop 15 10-20-2007 10:29 AM
Oil Dipstick? fundyrider Trophy 3 09-29-2007 04:04 PM
Dipstick !!! Bluesprinter Sprint Forum 12 08-13-2007 09:15 AM
05 oil level / dipstick. DarkSkies Speed Triple Forum 3 08-05-2005 06:20 PM
