Springfield ArmoryMotorcycle.com Classifieds!BikeBanditAdvanstarMotorcycleShowsRacerPartsWholesaleMotorcycle.comTrident-Exhausts.comShopTriumph.comSportbikeTrackGear
SportbikeTrackGear
Old 05-27-2006   #1 (permalink)
Okay, i have had a new chain and sprockets installed this year. About 12k ago. I tried to adjust the chain today and i could not budge the chain. Before all the adjustments were simple and didnt require alot of pulling to tighten the chain. But now i cant get any further.
I am wondering if there is a limit on how much you can tighten the chain on the speed triple?
Anyone get to a point in which you could no longer adjust it?
I have had dealers before when i brought my bike in to get new chain and sprockets install the chain too long, and the adjusters were not reset, so basically i only had a bit of tightening space. I wonder if the same could be done with the triumph.
Thanks
http://www.lusori.com
Cement/stone/brick work in DC/MD/VA
http://www.cycleposers.com
forum for motorcycle idiots, retards and morons
roadkill is offline   Reply With Quote
Old 05-28-2006   #2 (permalink)
13
Favorite Bike: BRITTEN
Other Motorcycle: 955i
Assuming (making an ass out of you and me) you loosened adjustment bolt enough, if spanner doesn't turn concentric - try a flat driver/ light tap with hammer on adjustment notch(seriously). Counter-clockwise's tight, about two inches slack...
If turning concentric doesn't tighten chain much, it may be at limit. Take it back to whoever did work and tell them to redo it properly (ensure new link used on chain).
Hope this helps!
SPEED SAVESİ
13 is offline   Reply With Quote
chain adjusting ricster Sprint Forum 14 09-04-2007 01:19 AM
chain adjusting ctrhenry Speed Triple Forum 11 05-04-2007 10:22 PM
Adjusting the chain! eagle Twins Technical Talk 10 05-01-2007 07:27 PM
Adjusting Chain - How to/How often? max_ax Twins Talk 8 04-04-2006 12:37 PM
Adjusting chain on RS KLH Sprint Forum 1 02-27-2005 06:59 PM
