On 2006-05-27 04:39, Spendthrift wrote:
Whats involved in the upgrade?
Drain brake fluid, loosen banjo bolt on stock m/cyl, remove m/cyl, put new one in it's place, reassemble and put new brake fluid in + bleed brakes.
Easy job for the diy man.
Remember to get new copper/aluminium crush washers for the banjo bolt also as they are 'use once'-items, especially on brakes.
[ This message was edited by: Martin_R on 2006-05-27 04:47 ]
