Springfield ArmoryMotorcycle.com Classifieds!BikeBanditAdvanstarMotorcycleShowsRacerPartsWholesaleMotorcycle.comTrident-Exhausts.comShopTriumph.comSportbikeTrackGear
SportbikeTrackGear
Old 05-27-2006   #1 (permalink)
Hi and apologies if this is already covered elsewhere (I did look):
I have done 250 miles and my new 06 S3 and have a problem with a slight lag between closed and small throttle openings, like when you might be on a long corner and want to go from a closed throttle to a neutral or slightly open ready to exit. I have adjusted all the slack out of the throttel cable to try and minimise it, but it's still there. I find I am pitched slightly forward as I brace for the power which doesn't come and then lurch back in my seat (ok only a bit), when the power comes on. It's a bit disconcerting on a bike that takes so much input through the bars, I keep thinking I will get caught napping and end up twisting over the wrong side of the road.
Has anyone posted ot even better corrected this?
thx
Tim
fryingtonite is offline   Reply With Quote
Old 05-27-2006   #2 (permalink)
Mine's doing the same thing with 500 miles on it. It went to the dealer for the first service last weekend and told him I wanted him to look at this problem. It feels like a bad setup on the throttle position sensor, but I thought Id let them deal with a warranty issue. They downloaded an updated map and took it for a test ride and told me they didnt notice anything, but its still there as far as I can see. Im pretty sure it hasnt got anything to do with throttle cable adjustment. You can feel the throttle open and it momentarily bogs and stumbles until it gets to 3000 RPM or so. I cant imagine we're the only people seeing this problem. Anyone else?
livefree63 is offline   Reply With Quote
Old 05-27-2006   #3 (permalink)
Limited Access
Its a common prob. Get your mechanic to take out the lag at the main throttle body on your first service. if u do it to tight u will have problems starting the bike. tell him u adjusted the cable at the throttle end. their was a thread on this a couple of days ago, havent had enough coffee yet to go look for it, know it was under throttle lag. good luck. :-D
Limey is offline   Reply With Quote
Old 05-28-2006   #4 (permalink)
I have only had mine about a year and rode the bike for a while totally stock and i noticed it also. It may have to do the FI period, meaning there is just some lag and will never be as smooth as a carburated bike. Only my opinion.
However you can greatly improve this with an exhaust and the Triumph performance tune for the ECU.
Robert W.
RbtWbbr3044 is offline   Reply With Quote
Old 05-28-2006   #5 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
The lag is a little disturbing during cornering, I need to fix mine. Too abrupt! I took out the slack from the throttle cable.
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Old 05-29-2006   #6 (permalink)
Mine does the same thing. I started a thread here about it and everyone replied that thier bikes are smooth as silk. Now I read this thread and the replies are saying thiers is doing it to. ***? Link to my thread is here:
CLICK HERE FOR MY THREAD>
Well Livefree63 said his did it. ANywho im curious to find out what the dealer says about it so I can fix mine. My GF almost fell off the back today when the power came on.
[ This message was edited by: Hotmailjerk on 2006-05-28 23:27 ]
Hotmailjerk is offline   Reply With Quote
Old 06-22-2006   #7 (permalink)
Have about 130 miles on a week old S3 with this same issue. Under light to medium acceleration from 2000 RPM I will feel a pretty good stumble right at about 2900 RPM. Give more or less throttle than that and I won't feel it.
Has anybody found a cure for this?
etachell is offline   Reply With Quote
Old 06-23-2006   #8 (permalink)
Just to update on my original post:
My issue was from a closed throttle; I took it back to the dealer for its first service and asked them to check it. The mechanic rode it after the service and pronounced it normal for a Speed Triple. On the ride back I noticed it was slightly better than normal and put that down to a re-tensioned chain taking the backlash out of the drivetrain.
Re-reading a copy of Superbike noticed this:
"Fuelling isn't perfect with a slight lag from a closed throttle".
So there you go. It looks like it is normal. Fuelling probably would benefit from a re-map/PCommander.
I reckon you can minimise it by taking up slack on the throttle cables/chain even getting the handlebars spot on and not having too much pitching backwards and forwards from the suspension. But the real solution is electronic IMHO.
Tim
Old 06-23-2006   #9 (permalink)
PS or maybe the TORS with the off-road re-map? Anyone done this and noticed a difference from throttle response?
T.
Old 06-23-2006   #10 (permalink)
I recently read an article about quite a few 06 fuel injected bikes (not just Triumphs) having problems with glitchy power delivery. Something to do with new emission laws and leaning the mixture off or something. Maybe Triumph is doing this?
bvivers is offline   Reply With Quote
They closed it GeoDiablo Twins Talk 14 10-17-2007 12:01 AM
Engine stumble britone Club Cafe 0 05-08-2007 03:44 PM
Tune and Stumble... dkurtz Triumph SuperSports 3 03-26-2007 09:03 PM
stumble at 9500? nostatic Triumph SuperSports 2 05-10-2005 11:03 PM
Throttle closed and a whirring noise! jmrharwood Daytona Deliberations 17 11-11-2003 11:54 AM
