For 2002MY onwards, Acumen's loom kit for the 955i Daytona works.
Fortunately, I have a nosecone fairing on my S3, but for those of you who don't, the loom is somewhat excessive. It would be difficult to hide! I have advised Acumen of this.
Apart from being a case of removing the tank and airbox to get at the 3 pin speed sensor connector, and the excess lenth of wire, fitting was relatively straightforwards.
Programming the device was "interesting"! Finding a suitable bit of quiet road , then riding along concentrating on anything but was a challenge!! Worked though.
My only criticism overall is that the "refresh rate" of the unit is painfully slow at anything under 4000 rpm, or low road speeds. So slow in fact as to render it almost worthless from what I've seen so far. However, that was only a few miles last night: I'll reserve judgement until I've given it a proper run.
Does not play well with others!!!
