BikeBandit
Old 05-10-2006   #1 (permalink)
2004 Speed Triple-what is it...T595,955i....or...... :???:
hal26 is offline   Reply With Quote
Old 05-10-2006   #2 (permalink)
...955i :???: :hammer:
Not a dumb question at all...although I believe that even on your SE it says 955i on the instrument cluster...I know it does on mine.
-Russ
LndSpd03 is offline   Reply With Quote
Old 05-10-2006   #3 (permalink)
Speed Triples;
98/99 = T509 (carbs)
2000/01 = T955/955i (fuel injected)
02-04=955i
05+ = 1050
pretty sure thats how it goes.
The T595 is the Daytona, but essentially the same parts as the T509/T955, with the motor as exception. Different cams and other cast bits. Otherwise, the bikes are nearly identical. Some structural changes with regard to the fuel tank and a few other bits for 02-06, but most parts are interchangeable. I think we did a post on this a while back.
[ This message was edited by: kuhlka on 2006-05-10 10:43 ]
Old 05-10-2006   #4 (permalink)
On 2006-05-10 10:40, kuhlka wrote:
Speed Triples;
I know the T509 was also available in '97. I thought it got the 955 engine in '99.
Were the T509s really carburated?! I had a '97 T595 Daytona and it had Sagem fuel injection. Since the T509 was just a smaller version of that motor, I presumed it had fuel injection, too. No?
[ This message was edited by: Curmudgeon on 2006-05-10 10:59 ]
Curmudgeon is offline   Reply With Quote
Old 05-10-2006   #5 (permalink)
Mclaren58
94-96 speed triples have carbs. In 97 they changed over to the oval frame and EFI
Old 05-10-2006   #6 (permalink)
Also, if you didn't know, the SE stands for Slow Edition! :-D Just play'n fool, I like the 04 SE, looks good! :-D
cheapbastard is offline   Reply With Quote
Old 05-10-2006   #7 (permalink)
The T509 I believe were also 885 displacement and I know for a fact that they were fuel injected
TonUp wrote:
Are you a Hooligan? I know that Corners and Cheapbastard are for sure and so am I!!!
http://i56.photobucket.com/albums/g1...-hooligans.jpg
corners is offline   Reply With Quote
Old 05-10-2006   #8 (permalink)
Favorite Bike: 1995 Triumph Speed Triple
Speed Triples;
02-04=955i
05+ = 1050
See, there we go again forgetting about the 94/97 = T300
Travis
Albany, NY
tealetm is offline   Reply With Quote
Old 05-10-2006   #9 (permalink)
I wasn't ignoring the oldies, just couldn't remember the call numbers.
So it goes?
94-96 = T300 (carb'd original S3)
97-99 = T509 (885cc switch to EFI and current frame)
2000/01 = T955/955i
02-04=955i
05+ = 1050
Track Day question FelixLeiter Speed Triple Forum 1 06-19-2006 02:33 PM
Stupid question of the day PaulK Club Cafe 3 05-17-2006 08:20 AM
Question of the day RandyDTFR Club Cafe 10 04-07-2006 10:03 PM
Dumb question of the Day ThruxtonMI Club Cafe 4 06-22-2005 07:19 AM
Track Day question sangsters Triumph SuperSports 1 05-07-2004 11:52 AM
