it could be worse. let me remind you. it is entirely possible that you could have done something even more stupid such as:
1) got drunk
2) let your friend drive home because of it
3) then when you get home say "you better let me park so you don't hit my bike"
4) back in instead of pulling in forward
5) knock your most prized possession over
who would do something this stupid? i dunno. then again, at least "that guy" above can blame alcohol.
unfortunately the bike next to the triple dinged the tank and rear seat cowl. doah!
the idiot above has some of that pj1 case paint coming tomorrow. he intends to sand down said case to remove minor scratches and paint. this should fix this problem. idiot will post pics so you can probably do the same.
those casing on either side are couple hundred a piece otherwise.
WELCOME TO THE PROGRAM!!!
