Motorcycle.comMotorcycle.com Classifieds!RacerPartsWholesaleBikeBanditSportbikeTrackGearAdvanstarMotorcycleShowsShopTriumph.comSpringfield ArmoryTrident-Exhausts.com
ShopTriumph.com
Old 05-08-2006   #1 (permalink)
What are the most common causes for an engine light to come on? I had just a touch of coolant leak out, but it isn't running hot. I figured it was the overflow, but it isn't confidence inspiring. The closest dealer is about 70 miles away. I'd like to take care of it myself. Any ideas on what I should check?
If you only do what you've already done, you can only get what you've already got.
AMRAAM: Advanced Medium Range Air to Air Missle. Just to clear that up..
amraam is offline   Reply With Quote
Old 05-08-2006   #2 (permalink)
Check your battery connections...
Short electrical ground, loose cables, etc is the most common cause. Otherwise, listen for strange noises and take it into the dealer if you can't readily see the cause. Also, cycling the motor up to operating temp then off a few times generally clears a fault if it is just a fluke.
Old 05-10-2006   #3 (permalink)
Thanks. It turns out it was nothing. After a few cycles it went off. I'm glad it was nothing. I have to travel a distance to get to a mechanic.
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 09:58 AM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 09:18 AM
Got RS going, now engine light is on.... jellero Sprint Forum 13 12-18-2005 10:04 PM
Fuel light/Engine light zore Modifications & Workshop Talk 1 06-28-2004 12:52 PM
Engine light on BruceG Sprint Forum 3 04-26-2004 01:32 PM
