The bolts that hold my ignition tumbler in place (2001 Speed Triple) worked themselves loose while I was riding and even fell out, thus causing my tumbler to fall down the triple tree. When I turned, it sheared off the key. The majority of it is still in the ignition. I have to hit the hardware store in the morning to get bolts that will fit it (And loctite will be used) and then I should have one issue fixed. The issue that I am looking for help on is this: Does anyone here have a good idea on how to get the portion of the key that broke off in the ignition back out? If I slide the dust cover out of the way, I can see it. I think the portion of key still on the ring will touch it too. I thought about super glue but I worry that I will mess up the tumbler in the process. Any good ideas?
If you only do what you've already done, you can only get what you've already got.
AMRAAM: Advanced Medium Range Air to Air Missle. Just to clear that up..
