RacerPartsWholesaleTrident-Exhausts.comSportbikeTrackGearSpringfield ArmoryShopTriumph.comMotorcycle.com Classifieds!BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 05-05-2006   #1 (permalink)
New to the forum and hoping someone can help....
I just picked up my new 06 Triple and when I got it home I started reading the manual and when trying to take a look at setting the clock and trip meters and such everything seems to work wrong....
First, the scroll button does absolutley nothing, second, when I hold the scroll button and set button to set the clock the Speedo starts flashing 2.
Anybody else have these issues? I know it has to go back but I was wondering if someone might have found it's just a firmware upgrade or something....or how long it took their dealer to swap out the cluster....
Thanks in advance.
kdriven is offline   Reply With Quote
Old 05-05-2006   #2 (permalink)
I just read through about 100 cluster display issues on some of the other threads...looks like Triumph needs to focus some efforts on these things!
Old 05-05-2006   #3 (permalink)
Sounds like As far as I know, the only reason for the Speedo to flash "2" is when you have previously pressed all 3 buttons on the cluster for 4 seconds. At that time, the speedo will flash "1", "2" or "3" - you should be able to use scroll to cycle between them. I can't remember which is which, but these three settings are: kph + litres, mph + US Gallons, mph + Imperial Gallons.
Sounds like maybe one of your buttons is stuck or shorted. Time for a cluster swap for certain.
Good Luck!
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
Eldercanuck is offline   Reply With Quote
Old 05-05-2006   #4 (permalink)
1: kph/liters
2: mph/UK mpg
3: mph/US mpg
Curmudgeon is offline   Reply With Quote
Old 05-05-2006   #5 (permalink)
I had a similar issue where a button lost it's "click" had to get the whole cluster swapped out... my dealer were really good about it.. needless to say I was disappointed about the quality of the unit... Plus I am not constantly worried that the buttons are going to fail on me...
ZARD Full stainless system, BMC Air Filter, DynoJet Powercommander,Pazzo Short Levers, Renthal Ultra Low Bars, Rizoma Fluid Reservoir, Oberon Bar-ends, Renthal 45T Rear Sprocket, Renthal 17T front Sprocket, AFAM Gold Chain, Triumph Hugger, Belly Pan !
gstar is offline   Reply With Quote
electronics failure??? help joshuacoleman Triumph SuperSports 6 07-08-2007 01:40 PM
Flaming Electronics! 2Scared2Wheelie Speed Triple Forum 3 04-10-2007 02:21 AM
Rain vs. electronics deaddeaddead Speed Triple Forum 4 12-16-2006 11:54 AM
Instrument Cluster OG-MOON Speed Triple Forum 0 06-09-2006 07:16 PM
cycle electronics Modifications & Workshop Talk 4 07-10-2004 02:53 AM
