AdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.comBikeBandit
BikeBandit
Old 05-02-2006   #1 (permalink)
I just replaced my oil and I noticed a small drip. It looks like it's originating from the oil filter. I tightened it as tight as I can by hand and it's still dripping.
I've used the FRAM Tough Guard TG7317 which is supposed to be a comparable replacement.
Do you use a tool to tighten the oil filter? I never had to on any of my other bikes or cars.
www.RainierArms.com
Teknic is offline   Reply With Quote
Old 05-02-2006   #2 (permalink)
Well, you've got a problem bigger than your oil leak... You used a FRAM! Those things are evil and rated the lowest by reviews I've read. I'd post them, but I'm sick of oil posts.
Did you use a new crush washer on your drain plug? I got a slow leak when I didn't replace the washer.
Old 05-03-2006   #3 (permalink)
Take the fram off and throw it away. replace with a different brand and make sure the gasket area is free of gasket material.
Hotmailjerk is offline   Reply With Quote
Old 05-03-2006   #4 (permalink)
I guess I better use the Purolator PL14610.
Have you guys heard of this filter?
http://mymiata.paladinmicro.com/MiataOFilters.htm
Advance Auto TotalGrip. It's at the bottom and they compare it with the Purolator and a lot cheaper. I think I'll give that a shot.
www.RainierArms.com
Old 05-03-2006   #5 (permalink)
Is it worth saving $3 to use a filter that you don't know much about. How often do you change your oil - two, three times a year? The purolator is well recommended by many members of this forum......thats what I would use.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Oil leak from oil cooler pipe? FlyBri Twins Technical Talk 3 06-21-2007 11:58 AM
Oil leak, right-side oil cover Rincewind Tiger Workshop 2 05-30-2007 10:36 PM
oil filter seal failure - oil leak / spray mlc Twins Technical Talk 7 05-25-2007 03:09 PM
oil qty for oil & filter change??? cheapbastard Speed Triple Forum 8 03-29-2006 09:56 AM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 08:43 AM
