AdvanstarMotorcycleShowsTrident-Exhausts.comBikeBanditMotorcycle.comSportbikeTrackGearSpringfield ArmoryShopTriumph.comRacerPartsWholesale
Old 05-02-2006   #1 (permalink)
Hi Guys,
I have bought a Paddock Stand for my S306. I must say that it is very unstable. The stand is made for the Triple but there is only a small pin going into the rear wheel. Am I doing something wrong?
It is not that life is too short, it is just that you are dead for so long...
Hood49 is offline   Reply With Quote
Old 05-02-2006   #2 (permalink)
hey Hood,
Is the pin a snug fit in the rear axle. Some other SSA bikes such as Ducatis have different diameter axles and use a smaller diameter pin. I think the pin should be 27mm diameter........I just went out and checked mine.....27mm is correct. Anything smaller and the bike would feel unstable on the stand.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 05-02-2006   #3 (permalink)
Hi Legman,
I will have th check what the diameter is. It looks bigger in the beginning of the pin but it gets small at the end. You might be right that it is actually to small. It is so unstable that it is tricky taking the rear wheel off!
I am going to check this evening!
Old 05-02-2006   #4 (permalink)
I don't understand the taper in the pin your describing. What brand stand do you have? My pitbull stand doesn't have a taper in the pin. It does come with 2 pins, one for the hub side, and one for the wheel side. Check that out, sounds like someone sold you the wrong one or something.
cheapbastard is offline   Reply With Quote
Old 05-02-2006   #5 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
I think the BikeLift rear stand I have also has a slightly tapered pin that matches the taper in the rear axel. But even with the taper there is no way the bike is going anywhere as the pin is such a tight fit and the bike itself is applying lever force to the pin.
I would have to agree with the others: you have the pin for some other 1 sided bike on your stand. The MV, Ducati, Honda have smaller dia holes in the rear axel.
Martin_R is offline   Reply With Quote
Old 05-04-2006   #6 (permalink)
I am going back to the dealers next week because I guess that he sold me the wrong one. I have some Italian make, cant remember. I will let you all know. Thanks!
Old 05-05-2006   #7 (permalink)
I bought a K & L stand that only came with an axel pin for a Ducati that was 26mm O.D. The S3 was unstable and almost fell off the stand after two wheel rotations. I measured the axel and had a pin made from a machine shop. It is a straight pin, 120mm long by 28mm in diameter with no shoulders. The big problem was the axel itself. The inside of the axel is uneven with ridges that had to be reamed out smooth. The mechinist did this with a sanding strap (medium grit) mounted on a drill bit. The pin fits tight. Now the wheel can be turned indefinitely without the bike falling off the stand.[img]http://www.msnusers.com/_Secure/0TQApA*IWMmymq7h5odXk8e2THlBkKma62rpWWp1tPkGECylH7 wOg46xKWQ6EHIJPhIwwIJmNnm26EE6Admiqbd4YqFfMsu2w79H txY2s2WGd2lIuchxBMg/DSCN4794.JPG?dc=4675571277446837341[/img]
I wave to ALL bikes.
Skydakine is offline   Reply With Quote
Old 05-05-2006   #8 (permalink)
Sounds like you dealer thought Triumph and Ducati stands are the same. The Triumph stand has a larger pin.
Aaron B.
'00 Kawasaki ZX-9R
'06 Nissan 350Z
'87 Nissan Hardbody - The "Mud Mobile" (443,000 miles and counting)
i8acobra is offline   Reply With Quote
Old 05-10-2006   #9 (permalink)
I have been back to the dealers and they have confirmed that the stand is a bit wobbly! They have ordered a new one! Hope that this time they have got it right!
Thanks for your input guys!
New paddock stand after stand FAILURE!!! xactoman Daytona Deliberations 7 08-15-2007 09:50 AM
Paddock Stand TCBLF Club Cafe 1 10-07-2005 09:15 PM
rear wheel stand (paddock stand) for TBS Hinckley Classic Triples 5 08-29-2004 02:43 PM
Paddock Stand Daytona Deliberations 4 08-18-2004 02:35 AM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 10:31 PM
