Hey jdub, the headlight wiring is pretty simple. There will be only 3 wires in in each bucket for each lamp. High, low and earth. It's easy enough to take the lenses and lamps out, from there you just need to inspect all the wires, looking for melted plastic casings, and rubbing. Also check around the steering neck where the wires come out from under the tank.
Have you got that manual yet? You may need to see a picture or wiring diagram to figure out which is which wire.
If the high beam indicator lamp is only partially lit, it could mean only a partial dual connection between high and low beams. Difficult to diagnose in print.
On other thing it could be is something to do with the indicator light itself in the dash, but it's so different to mine I wouldn't know were to start.
good luck
Mick
[ This message was edited by: miker on 2006-05-03 17:31 ]
