Tank should be the same or very similar to previous years since the tank, tail, and subframe are cross-compatible. The tank should have the two side-panel bolts, a bolt at the front top by the triples, and a bolt under the seat which bolts onto the subframe. Once you have all the bolts out, just be careful with the fuel fittings as they tend to be a tight fit, and keep track of all your hose connections before you yank the tank off.
The tail should be fairly simple as well.
