Old 04-29-2006   #1 (permalink)
I asked this several weeks ago...
I'm in neutral sitting still.... shift into first... whack... not a little sound but a big whack sound....loud.... neutral to second sitting still big whack sound again.... loud!!!! is everyone sure this is normal.... really loud....
Sounds like the clutch/plates??? or something isn't slowing down or stoping when you put it into gear??
380 miles on the bike and it's an 06
Sitting still again.... put into 3r gear let out clutch and you can hear a semi loud click and the chain moves before the clutch is let all the way out... bike still sitting still, does the same in 4,5,and 6th
bike goes in and out of gear poorly???
love the bike, but this transmission problem is killing me.....
calling the dealer on Tuesday (not open on Monday) just wanted to get as many comments before I have to take it in.... big hassel???
Please let me know??
"GO BIG OR GO HOME!"
CaptainMorgan is offline   Reply With Quote
Old 04-29-2006   #2 (permalink)
Have you checked the gear linkage for excess play and correct adjustment? So all your foot movement is actually transmitted to the gearbox and not just a tiny amount of it.
Martin_R is offline   Reply With Quote
Old 04-29-2006   #3 (permalink)
Diego's Avatar
No, it's definitely not normal. Probably more of us should have keyed in on your earlier description of it as loud. These additional details are not things I've ever encountered on a Speed Triple.
Both the gearshift linkage and clutch lever play should be checked, but this may well be a less common clutch fault the dealer needs to examine under warranty. I'd at least contact the dealer about it. I wouldn't wait for the 500 mile service.
John
Old 04-29-2006   #4 (permalink)
Give the bike a short rev to loosen up the clutch while you've got the clutch pulled, wait a few seconds for the revs to drop back down to idle then try clicking into gear. If it still clunks you're definitely out of adjustment somewhere. Where does your clutch lever have to be pulled to engage the clutch?
Old 04-29-2006   #5 (permalink)
kuhlka.... probably somewhere around 1/4 inch and the clutch starts to engage.....
on adjusting the clutch lever... I'm confused??????
Acording to the manual is shows you shold have 2-3mm between the knurled knob and the lever..... I have about 1/2 inch to 3/4 inch....
or are they saying 2-3mm of play between the lever and lever bracket... I always thought clutch play was on the lever not between the adjuster and the lever bracket???
Old 05-01-2006   #6 (permalink)
i get a very loud clunk engaging first and the first to second is harsh too.
how do you check the gear linkage for excess play and correct adjustment? So all your foot movement is actually transmitted to the gearbox and not just a tiny amount of it.
im a mechanical leper so go easy on me
officer you try and keep it on two wheels
Celt is offline   Reply With Quote
Old 05-01-2006   #7 (permalink)
Does the bike try to creep with it in gear and the clutch in?
littlefield is offline   Reply With Quote
Old 05-01-2006   #8 (permalink)
littlefield.... no creeping at all..... just click it or clunk it into gear start letting out the clutch and then you hear a click and the chain moves....
Anyone going to help out celt and myself on our questions??????
Thank you...
Old 05-01-2006   #9 (permalink)
Lever and bracket.
Sounds like the clutch is not fully disengaged.
PhilM is offline   Reply With Quote
Old 05-01-2006   #10 (permalink)
Moderator
Favorite Bike: 2006 Tiger
miker's Avatar
Other Motorcycle: 1982 Harley "Sturgis"
Extra Motorcycle: 1986 XR 200
Best thing to do before waltzing off to the dealer is re-check the clutch adjustment. Make sure that the cable is adjusted correctly at the gearbox end, it's hard to describe in print, but here goes.
Loosen the cable from the lever end, by screwing the brass fitting all the way in to the lever perch. Then go to the gearbox end and check how much play there is in the actuating lever. It should be about 1-2 mm. By this I mean, grab the actuating lever with your finger, push it, and see how far it moves towards the direction of pull of the cable before it stops. If it's not 1-2 mm, then adjust it by loosening the lock nuts either side of the cable carrier, then tighten the one closest to the cable until you get the right freeplay. Once this is right, then go up to the lever perch and screw the brass fitting out until you have about 2-3mm of play at between the lever and the perch itself.
Then start the bike, put it in 1st - ignore any clunks, but see how far out you have to release the lever before the clutch starts to move the bike. It should be somewhere between 1-3 CM (an inch or so). If it's less, then you have too much free play still. If it's more, then not enough free play.
The S3 boxes are very clunky when new and do settle down, but from the sound of what you are saying, the clutch is improperly adjusted, which is a simple check and re-adjust that any one can do.
Hope this helps,
Mick
My Album
miker is offline   Reply With Quote
06 Transmission T100Tom Tiger Chat 11 08-06-2007 01:46 PM
Going to the Shop:-( Transmission? Clutch? akjohn Sprint Forum 0 07-20-2007 03:30 AM
out of my transmission 77bonniehotrod Classic, Vintage & Veteran 1 06-25-2006 04:16 AM
Transmission grinding fbird The Rocket Science Forum 8 09-30-2005 09:58 PM
Transmission Leak Will Classic, Vintage & Veteran 8 05-07-2004 05:49 PM
