On 2006-05-01 20:11, kuhlka wrote:
The throttle is a bit easier as it has a single adjuster covered by a rubber sleeve between the throttle and ignition switch.
Note: on the 05/06 it is a dual cable throttle, one pull - one return. Not sure about other years.
To accurately take the slack out of the throttle you need to do it from the throttle body end under the airbox.
I don't have any advice about Cap'n Morgan's issue. I think there may be either more trouble here than most of us think,
or he's worried over nothing.
Dunno.
[ This message was edited by: crashmasterd on 2006-05-13 20:35 ]
