ShopTriumph.comRacerPartsWholesaleMotorcycle.com Classifieds!AdvanstarMotorcycleShowsMotorcycle.comSpringfield ArmoryBikeBanditTrident-Exhausts.com
Old 04-28-2006   #1 (permalink)
Hi guys,
Just bought a Scorpio SR-i500SE alarm system to put on my bike... I know we are supposed to connect to lights wires and all, but I don't have the shop manual...
So those of you who did install this system, can you tell me what wire you used and also if you have a picture of your installation it would help me a great deal!...
Thanks
HDeno is offline   Reply With Quote
Old 04-28-2006   #2 (permalink)
aaronb_dsn's Avatar
i got a connector that hooked right up to my factory plug under the seat.
you have to call for it, its not on the site.
aaronb_dsn is offline   Reply With Quote
Old 04-28-2006   #3 (permalink)
Aaron: I am surprised you got that connector because I wrote an E-Mail to Aritronix and a guy named Anthony replied saying they are developping a connector for it but it won't be available soon...
He told me however that the GEN-1 connector supplied with the alarm kit should work, but I think it uses the crimp-on t-connectors...
Do you by any chance have the part number of the connector you bought or who did you talk to to get it?...
Thanks
Old 04-28-2006   #4 (permalink)
What's wrong with these guys?. I suspect their mail server must be down. Two emails and not one reply..........sheesh..........
Avi8or is offline   Reply With Quote
Old 04-28-2006   #5 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
HDeno, if you do not manage to locate the connector via the alarm company the Triumph alarm plug is the following part:
Plug: TYCO AMP 173851-1 / RS 362-9086
Female: TYCO AMP 174933-1 / RS 362-9193
Push-in pins: TYCO AMP 175029-1 / RS 362-9373
The -1 indicates white part, do not remember which was black. In any case the whites & greens are much easier to find. They are otherwise identical parts.
You should be able to buy/order the connectors from your local electronics store for a few cents a piece.
Blinkers, starter power, switched power and all needed wires are present at the plug, so I would recommend wiring your alarm with the plug instead of raping the stock wiring with crimp-ons. The plug approach worked very well for me, when I wired in a custom alarm with no Triumph harness available.
[ This message was edited by: Martin_R on 2006-04-28 10:15 ]
Martin_R is offline   Reply With Quote
Old 04-28-2006   #6 (permalink)
Martin_R: Thanks for that very useful information... Now I will just try to find which connector corresponds to what on that plug...
Old 04-28-2006   #7 (permalink)
Favorite Bike: 06 Daytona 675
Punkinwing's Avatar
Other Motorcycle: 08 Rocket3T
Extra Motorcycle: 01 GL1800 (Wife's)
The crimp on connectors in the kit are pretty high quality and worked well enough for my needs.. Velcro the unit to the top of the battery and the tails were long enough to reach to the tail piece to tap the turn signal wiring..
There's no such thing as a stupid question, but there seems to be a lot of inquisitive idiots around..
Punkin Dave
MSF RiderCoach
Punkinwing is offline   Reply With Quote
Old 04-28-2006   #8 (permalink)
Martin_R's Avatar
Check your Triumphrat.net private messages...
[ This message was edited by: Martin_R on 2006-04-28 11:53 ]
Old 04-28-2006   #9 (permalink)
Thanks again Martin, your info is greatly appreciated!...
Old 04-29-2006   #10 (permalink)
I got a used Scorpio alarm but I have no idea what model number it is or if I even have all the parts. Do you know where I might look to get some information?
www.RainierArms.com
Teknic is offline   Reply With Quote
Scorpio alarm - 2007 Sprint ST Black_Panzer Modifications & Workshop Talk 3 06-16-2007 08:36 AM
Scorpio Alarm mack82097 Sprint Forum 2 08-22-2006 10:02 AM
Scorpio alarm & Sprint ST 1050 KevyKev Sprint Forum 1 07-14-2006 08:54 AM
Scorpio SR-i500SE alarm McDave Modifications & Workshop Talk 5 01-07-2005 03:24 PM
